rob2
Just idle musing on my part, but ough to be considered, perhaps. Every engine manual I have ever read (quite a few now) gives a maximum angle for insallation and then says that the dipstick is set for a level installation (never seen one of those) and the oil level should be adjusted to suit the angle. In what way does it suit? Should the quantity remain the same, or should the level be maintained at some notional point? Thinking about it, the critical point is the relationship between the oil level and the pick-up pipe, but no manual ever tells you where that is.
Come on, you marinisers! Print a graph showing how the level should be maintained relative to installation angle.
Rob.
Rob.
