prv
We always knew that Ariam had some crud in the tank, but yesterday was the second time in not many days' use that a lump of it apparently got stuck in the dip tube. Fortunately without stopping the engine, unlike last time, but there was some nervous watching of the suction gauge until it suddenly cleared itself (the crud presumably passing into the filter). So the tank definitely needs a good clean out, and rather than keyhole surgery I want to get at the inside by hand.
The tank is relatively thin stainless steel, and the top is easily accessible. I'm familiar with the Wema plastic hatch (we had one on Kindred Spirit) but I don't think that would work as well on thin steel as it did on thick plastic. So I'm thinking of making a square version of the Seabuilt hatch - easier to fabricate in an unsophisticated home workshop and doesn't need clever tricks to fit through the hole!
I think I know how I'd go about building that, but any observations from other successful hatches on plate thickness, bolt spacing, and gasket thickness would be welcome.
Also, ideas on cutting into the tank? I'm not going to use an angle-grinder in a moderately confined space, quite apart from any fire risk. Jigsaw? Buy a nibbler? For some reason air ones seem to be much more common than electric, but are no good to me as I don't have a compressor. I've found one designed to be powered by a drill for £20 - are these ok for one job or complete rubbish?
How big a risk is igniting any diesel or fumes left in the tank, and what if anything to do to prevent it?
Cheers,
Cheers,
