JS PLEASURE
Where can I get the injectors checked on my Volvo Penta 2003 TAMD22 p-b engine.
Many thanks for the information, I live near Exeter, Devon.It might help if you tell us where you are as then someone can share local knowledge. Often The Yellow Pages and Google are fine and look for a local diesel injection specialist. Often it is only nececessary for the specialist to adjust the injectors and clean them . If necessary new nozzles will be fitted .
Have tried locally around Exeter, Devon but because it is a Volvo Tamd22 have been unable to find anyone who can check them because of the age.On re reading I assume you have a 2003 vintage tamd22 there is a 2003 model in the Volvo range which is totally different apart from the colour
The Tamd22 injectors can be checked in any competent diesel shop it is a cousin of a Perkins engine developed fo rover
Many thanks for the information, will contact them.If you are in the Plymouth area try City Diesel. I had my yanmar injector,stripped, cleaned and tested for £60.
