IanCC
Gosh. Injector pump? Fuel pump is new, like rest of low pressure system.By experience from a 2gm the feed pump can be the culprit re. (cold-)starting issues.
In this case it actually was a not very old OEM pump!
Thanks fir that. Mine is new, so hope it doesn't need replacing again. Will check though.Not the high-pressure pump feeding the injectors.
The error was a weak FEED pump, lifting the fuel from the tank to the high-pressure pump.
Never heard of them.An outfit called "Lucas CAV".
New boys perhaps?
I said for a tester not to have them tested!£15 is cheap. £60! Got mine tested for free.![]()
I knowI said for a tester not to have them tested!
Diesel Injector Nozzle Tester -Dual Scale 0-600 BAR Pop Pressure Tester 0-60Mpa 8085443084901 | eBay
These guys have nozzles that seem to suit. Also they list the equivalent in other makers.I know. Tell me, how did you know which cav lucas nozzles to buy. 'Trust they are better than the filters.
Really helpful, thank you.These guys have nozzles that seem to suit. Also they list the equivalent in other makers.
Düse - BDN 4 SK 1
Googling the Delphi number brings up... https://m.autodoc.co.uk/delphi/8258349
The reference numbers matched.I know. Tell me, how did you know which cav lucas nozzles to buy. 'Trust they are better than the filters.
