Inflatable repair
I'm trying to fix my inflatable. i've found the leak and now need to find an adhesive to attach the patch. The dinghy is an obscure make which i've not heard of but the material looks like neoprene. Any suggestions
<hr width=100% size=1>johnS
tr7v8
30 Nov 2001
Kent
As far as I know the only 2 options are PVC or Hypalon. I'd suggest a pukka repair kit.
<hr width=100% size=1>Jim
Draco 2500
oldsaltoz
4 Jul 2001
Australia, East coast.
G,day John,
Tip Top have a glue called FC2000, it's a 2 part mix, your local tyre repair outfit should have some, I have repaired a couple of holes in the inflatable (Zodiac) and no problems, just make sure you line the patch up, cos if you even touch it in the wrong spot, it's too late, no chance of removing it without a buffer. It's jet black so mark the location and don't spread it too far, it's hard to remove once applied.
Hope this helps.
Avagoodweekend. Old Salt Oz /forums/images/icons/cool.gif..........
