junksailor
Just bought a Narwhal MR240 inflatable tender with dodgy valves x2. Hoping I can fix it.
Had a fiddle and it seems that the nylon shafts with spring attached which allows you to deflate the boat and which the rubber valve seal is attached to are sticking in the open position,
I am hoping I might be able to free them with some sort of lubricant, but don't want to use anything that might rot the valve.
What do you recommend? Has anyone else come accross this sort of problem?
Can I remove the core of the valve, it is attached to the part of the valve outer casing which remains in the inflatable if you undo the outer nut and seperate the two halves.
