cazzascotta
Hello, I have got a Hummingbirdi 565 fishfinder and more than one friend said to me to use the default transducer (transom transducer) as in hull transducer and then, if it doesn't work, buy a in-hull transducer. I have found this phrase in a post in this forum on 3rd sept 2008:
"do you need to bother with tubes and fluid? Just a smear of silicone and stick it on. You can use epoxy, but its a bit permanent if the location isnt perfect! "
My questions:
1-I will put this aside of the existing through hull depth transducer withour removing it. But the GRP surface is not smooth as you know, not painted. Will the thing work? Will the silicone bed be enough to make it work?
2-I was thinking of putting a wood base on the GRP and then mount the transucer on this base with the silicon (or sikaflex) to get a horizontal surface, as the hull there starts to get a little inclination, though with a little gradient (Beneteau Oceanis 311). Will the transucer transmit also through the wood?
Has anyone any suggestion or comment?
Cazzascotta
My questions:
Cazzascotta
