westernman
A bow thruster does not have to be fitted to the boat.Suspect the OP knows all that.
His question was whether a different prop would help - which it might for getting greater waterflow over the prop. However one has to accept that no matter what you do control going astern with that type of boat is limited and the only way of real improvement is to have some control over the other end of the boat - hence a bow thruster is recommended.
Some one in a dink with an outboard works just fine.
Otherwise a warp hooked up to something (Ok a puller rather than a thruster).
