stu9000
picture is on its side for some reason.
The bottom is pointing left.
I have been doing battle with the engine an I I initially enjoyed and embraced as an important learning experience.
But the usually sweet natured Volvo md7a is sulking for some reason.
I changed the impeller at the start of last season and had no problems.
However the impeller isn't sucking water now.
Fresh impeller added.
New backing plate as the old one was heavily worn.
it is definitely rotating.
The hull to pump pipe isn't blocked.
I have disconnected the hose from the hull fitting and had the hose end in a bucket of water. No signs of sucking up water at all.
Tried new gasket, pouring washing up liquid down the pipe , adding an extra glob of grease all to no effect.
I suspect the inlet connection.
Not the hose that is jubilee clipped to the metal fitting, by the fitting that connects to the pump.
It is likely I disturbed the seal when I moved the hose to fit in a bucket.
I inspected the rubber washer. Seems fine.
I was quite surprised at how basic and loose the fit seemed, but it worked before so I whacked in a load of gasket sealant and put it all back together.
No joy.
I'm not sure where to go from here.
Maybe wrap some ptfe tape around the inlet fitting to get a tighter seal.
Seemed fine last season.
No overheat alarms.
Water coming out of exhaust.
So, I'm assuming I need to find the air leak so it can generate the vacuum needs to prime.
Any suggestions?
S
