mjcoon
But I have built far fewer cubits' worth of Noahs Arcs than OLdHarry, lol
Ah, of course: Noah was just hoping to join the Atlantic Rally for Cruisers!
Mike.
Hopefully, pics are attached .View attachment 41140
Looks like the s**tehouse door off a Grimsby trawler to me! Blimey I'd nearly forgoton that old chestnut!
Afrormosia is possible but the drain looks to "open" it is also an endangered species now so again less likely, i have chairs i made from it 40 yrs ago.I'm amazed that people can confidently distinguish between teak and iroko from the photo. It could well be teak, iroko, or afrormosia (or a few other exotics). I'd rate iroko as the least likely of these from the wild grain, but then, if it's relatively new, the statistics simply make iroko more likely. Anyone who can confuse teak and sapele is seriously short on wood knowledge. I have lumps of all in these workshop. I could tell you with certainty whether it is teak if I could cut it and smell it. Take a bit to your nearest shipwright and let him/her sniff.
Almost certainly Iroko. Have a board just like that with the same curly grain in my workshop. When you cut it the strips have a life of their own and spring to follow the grain - so not much use if the job require stability. Probably why it ended up in a Boat Jumble!I'm amazed that people can confidently distinguish between teak and iroko from the photo. It could well be teak, iroko, or afrormosia (or a few other exotics). I'd rate iroko as the least likely of these from the wild grain, but then, if it's relatively new, the statistics simply make iroko more likely. Anyone who can confuse teak and sapele is seriously short on wood knowledge. I have lumps of all in these workshop. I could tell you with certainty whether it is teak if I could cut it and smell it. Take a bit to your nearest shipwright and let him/her sniff.
Amazing talent - to be able to judge the 'spring' from a (poor) photo.
Just observing that iroko with curly grain like that can twist when machined into strips. Not saying it will, just that the grain is a good indicator of stability. In fact the plank that I had was very straight grained over most its width and the pieces I used from that for a hatch garage were stable, but the strips I cut from the bit that looked like the photo was unusable.
