ltcom
Battery flat on car this morning.
Stuck a battery charger on it which had 3 settings...... min amps, mid amps, high amps.
On high amps the battery should have taken 15 A and dropped slowly if it was healthy. It didnt. The amp needle hit the red.....meaning internal resistance i think. Yes i am no expert. I turned amp setting down for a few hours ..... 6 amps in..... then turned dial to setting 3 (high amps) and it settled at drawing 10 A then dropped GRADUALLY as it should ..... so i hope i saved my battery. If amps increased it would have been bad news again.
Car not used alot.... should have trickle charged it....my fault..... will see later if battery is ok or broken.
So dont leave cars unused for a month at a time....is what ive learned.
