Dave 71
A couple of weeks ago, I was shown how to remove the log transducer, put the bung in, clean it, and swap it back.
Today, after seeing 0.0 knots boat speed whilst bowling along at 5 or 6 knots, I decided to man up and make a hole in the bottom all by myself.
I took the transducer out and put the bung in with a satisfyingly small amount of water going into the bilge. I cleaned the log. Great, 50% successful.
I then spent the best part of 2 hours trying to get the bung out. It's stuck fast. I can get the female screw part/lid loose - at which point water starts coming in, slowly - but the bung won't shift. Two guys from the yard had a go, nope, it's stuck. I'm not 100% sure that the thread isn't somehow still binding when loose, but it loosens until it binds on the top (wider) part of the bung then goes tight and loose, whilst 'clicking' as you rotate it...
All I've been able to do is arrange a lift on Monday, but then what? My current thinking is that I try and push it up from underneath, or use a rubber mallet and a thin wooden bung or dowl and hammer it up, or cut the top off above the screw lid, remove the lid and hammer it down, and if that fails try and drill it out and somehow cut or grind away the bung (whilst saving the through hull.....)
Thoughts? Suggestions?
Have I invented a completely new boat problem?
I would leave it but the transducer is combined log and depth. Here in Essex I really don't want to be without the depth
