Hydraulic steering fluid - FEEDBACK, with tech advice
sarabande
6 May 2005
I asked a couple of days about loss of fluid in an elderly Wagner steering system, and received a number of posts.
I also emailed the manufacturer, Wagner, in Canada. Less than 24 hours later , a reply from Aaron Bruce, the Marketing Manager.
"What is more impressive to me is that we stopped making the A-W pump 25-30 years ago. There is little or no documentation left on these old pumps so that is why you cannot find anything posted online. Look at the 701 series information as these are the closest pump to the AW.
The recommended fluid is Hydraulic Oil Viscosity Grade 10 or 32. It does not matter what brand as long as it is hydraulic oil and viscosity grade 10 or 32.
I should mention a something I get out of your email. Make sure that the present fluid in the steering system is hydraulic oil. If it is not, then drain the system and flush it out. Then refill with hydraulic oil. Many people try to use ATF or Brake fluid and these oils increase the wear on the moving parts as well as erode the seals.
Just to give you a quick heads up the only part that is still available for these pumps are the seal kits.
Seems that this company believes in customer service. If I have to replace the pump or cylinders, they will be my first choice of supplier.
Perhaps the warnings about use of the correct fluids may be useful in preventing damage and corrosion in other Forumite's steering systems.
CONTACTS
http://www.wagnersteering.com/
Hamilton Jet (UK) Ltd.
Unit 4A, The Birches Industrial Estate
East Grinstead, West Sussex
England, RH19 1XZ
Phone: 44 1342 313437
Fax: 44 1342 313438
Contact: Peter Morgan
E-mail: peter@hamjetuk.com
No connections. Usual disclaimers.
Talbot
23 Aug 2003
Brighton, UK
From your previous post, it would appear that a purchase of a seal kit might be indicated.
and I dont mean:
sarabande
6 May 2005
I normally wage war on vermin, yet I might make an exception... but it would make an exceptionally nice pyjamas case !
DaveS
25 Aug 2004
West Coast of Scotland
I recall an old joke about "Canadian Club on the rocks..."
The OP makes me feel guilty. Some years ago the hydraulic steering of our hire boat on the Canal de Midi failed, and we tried to fix it by topping up with brake fluid from the supermarche...
