MapisM
Yeah, but that brings us back to my post #53...
I meant to reply to this ages ago. Yep, now you say it Jimmy, you're dead right, music aficionado that you are :encouragement:I don't know, I quite liked the sound - it's almost dubstep
On the main event, I haven't got hold of the court's judgement yet. Still trying.
Both my truck and van are in the shop this week for audio upgrades (I think nick_h has previously 'enjoyed' the audio system in the truck, I'm sure he'll appreciate another upgrade)
I hope you're doing it properly this time ....
I can quote an example from the days when my company was the master distributor for Naiad when they first started. Two nominally identical new Hatteras 53s (except that one was stabilized) were being delivered from the factory to Fort Lauderdale via the offshore route. The stabilized yacht ran almost 200 revs lower on the mains to keep station with the unstabilized one.
Better late than never! First of all, welcome to the madhouse.I'm probably joining in the thread a little late
Thanks for your interesting post, pdryan. Are you able to suggest average fuel consumption improvements across a range of different types of boats and speeds between stabilised and non stabilised?
Yes a helluva difference. On my boat a 200rpm reduction in rpm at planing speed is equivalent to a 20% drop in consumption. At displacement speed, the reduction is even greater. And this is why I asked the question because the difference seems huge. The accepted wisdom seems to be that fins cause drag at speed and therefore increase consumption but pdryan seems to be suggesting the opposite. It does make sense in principle thoughNow, I can't estimate by heart the difference in fuel consumption (though it's possible to make some calculations), but surely 200rpm is a helluva difference, with engines that quite likely were DDs...!
Precisely. My train of thoughts on pdryan post was as follows:At displacement speed, the reduction is even greater.
I perfectly see your point.
As I understand, on some modern systems, it's even possible to self-adjust dynamically the neutral fins center, because for any given hull, the angle you mention depends also on the speed, to some extent.
Otoh, if in a specific P hull the addition of a couple of fins parallel to the keel brings more benefits (in terms of higher lift and lower wet surface) compared to the obviously negative effect of additional fins drag, I can't help but think that the hull doesn't have enough inherent lift, to start with....
Well, based on what pdryan told us, your suspicion is obviously correct, at least for some Rybovitch boats.i suspect the lift drag ratio of a fin is far better than you could achieve with the hull surface. Isn't that the basis of hydrofoils?
What I'm saying is that if this would generally be true, most P hulls would have been designed from the beginning with some fin-alike appendixes.
Otoh, I'm not aware of any P boats like that, as well as I'm not aware of hydrofoil boats which weren't specifically designed as such.
Besides, each and every ultra-fast boat, bar none, have as little stuff touching the water as physically possible, for very obvious/intuitive reasons - see my previous post #94 for a practical example...
Mmm... I've seen all sort of weird ideas for increasing the lift and/or reduce the wet surface in planing hulls, some of them also rather sophisticated.I genuinely think people didn't think of it.
