syvictoria
Hi. I fear another stupid question coming up...! Sorry...!
Is the wing nut held cap design of the 1" hull/seacock mounted raw water strainer considered by the panel to be better than the screw cap on the 3/4" version, and would installing a 1" strainer with a 3/4" seacock and 3/4" hose risk introducing any problems with flow and/or priming (all assuming that 3/4" is sufficient for cooling purposes)? Would the additional capacity of the larger strainer offer an advantage over the smaller?
https://www.asap-supplies.com/raw-water-intake-strainer-hull-mounted-402024
https://www.asap-supplies.com/raw-water-intake-strainer-hull-mounted-402025
An above waterline strainer isn't an option due to the location of the seacock (in keel). Thank you!
