Ben Dockrell 22
As others have mentioned, all materials have advantages and disadvantages, you need to pick the one that suits your needs best.
Personally, I'd suggest that a well-maintained steel boat is probably the most easily available and cost-effective option. If you can find a good ferrocement one (and they do exist), then that's another good option. Although both methods of construction can produce heavy boats, if you're looking at anything 40 feet or longer, the difference between heavily built GRP and either steel or ferrocement gets increasingly small and irrelevant. You've already discounted wood, so I won't try to change your mind, although if somebody wants to do blue water in a wooden boat, there are plenty out there that will do the job fine (there's one called Suihaili for starters, although I don't think she's for sale).
If you're worried about hitting submerged objects at sea, then rather than worry about what to build the hull from, why not just get a boat that you like and is generally suitable, and install a forward-looking sonar? The last time I looked £1,500 would buy a top of the line (at least for civilian use) one, and they are available a fair bit cheaper than that.
I bet no-one in any government today* has been approached by anyone who wants to begin a project which surrounds all dangerous reefs and other hidden dangers with a heavily bouyed (layers of padded bouys) baracades which are designed to bring boats of size to a stop from which they reverse themselves out of and alert the relevent authorities.
The barrier works very much along the lines of racing cars going into mounds of used tyres until they come to a stop.
There would be different classes of them as judged appropiate for the danger present.
*I mean in terms of anyone in any government taking any notice.
