Daydream believer
Yes, but the resin internally was not like the resin you get when you mix 2 parts of ordinary west 2 pack. This was more like antifreeze consistency (but clear in colour). It had intense seeking properties & one flood brushed it on the surface. It was drawn into the wood & into any crack or void. When hardened the surface had a hard crystaline feel. The fumes were viciuos & wessex would only sell it to me once I demonstrated that I already had air assisted masks for my spray shop, to remove the fumes that were trapped in the hull area. I also had fans each end to blow the fumes away & the workshop doors wide open.Interesting. So the outside was sheathed with glass and resin, but inside the hull was simply treated with resin- no glass.
I’m thinking about going to take a look at a boat, with a view to buying. This too has glass/epoxy on the exterior but not inside. Carvel built, copper riveted. Nervous.
When done it took white Leyland floor paint very well, on the areas that were exposed to the cockpit & saloon. I did not coat the underside of the deck & cabin roof as these were new plywood, fitted after the hull was completed & sheathed externally. I did not feel that I wanted to use the product in an enclosed environment due to the fumes.
The problem with not sealing the inside, is that moisture can get behind the outer sheathing. I believe new boats can be sheathed externally, but I do not know if new boats are sealed internally. I would also point out that my boat was sand blasted first. This made an excellent surface for bonding. Much better than a flush sanded one, as the resin can soak in better. All paint, grease & loose wood was removed with a vengance.
