awyatybw
I have a Victoria 34. Relatively recent build – 1994. During a recent day out in a bit of a blow with a very short sea we had a lot of water over the decks and the port toe-rail spent quit bit of time below water. Later we discovered water in several of the lockers along the port side – not lots but enough to make a few things a bit wet/damp.
As far as I can determine, the construction involves an overlap of the hull and deck mouldings which are through bolted every 6-8 inches. It appears that some form of black sealant was used in the join. On top of this is a teak gunwale (is there a better term?) which is screwed in place, the screw-holes being plugged (although a few plugs are missing). The sealant between the underside edges of the gunwale and the hull, both on the inside and outside, has failed in many places.
Is it reasonable to expect that sealant between the two parts of the hull moulding may have failed? Or am I mistaken in my assumption that the black gunge that can be seen from inside the boat along the join of the hull and deck mouldings is a sealant between these?
Alan.
Alan.
