sailboatliving
I got a huge spark at least 1 inch when I started to unscrew the positive on the back of my Balmar K6 120 amp alternator, the engine and alternator was off. It left a mark on the tool.
Is this a short? I had only had the boat for 2 months and would not have been able to identify an alternator 2 months ago
The eyes on the cables are not touching the alternator chassis or the engine.
There are two positive thick battery cables on the alternator and one is connected to the engine and then battery switch on its way to the starter battery, The other which I think caused the spark is going to an 150 amp ANL fuse then to battery switch for house. I removed the cable on the ANL fuse (with just a minor spark) and then there was no spark at the alternator connection point.
A few days ago I removed the negatives for house and starter but the spark was still there.
My external regulator is not working so I was trying to hook up a wire for the internal regulator to work. But it is not charging, I connected the ignition wire and sense wire.
The alternator was (over) charging the batteries with the defect regulator (Balmar 614) connected.
I'm at sea of Cortez, far from nearest town and they will not have a marine alternator anyway.
Second question, what should I disconnect to run the engine without the alternator involved? The positive red cables? I can't remove the belt. The solar give just enough energy for the batteries if I ration
