How to remove old deck paint
Colvic Watson
23 Nov 2004
Norfolk
Did a search for this but couldn't find a thread. The deck paint on our new (old) Macwester is badly chipped and flaky in some places. Rather than sand down and chuck on a new coat to make it look 'OK' we wanted to get it back to the gel coat and start again. So questions questions:
1. After scraping, how do we get rid of the last bits? Is acetone OK and where do I get it?
2. Do I need to apply a primer coat or is rubberized deck paint self priming?
3. Is there any other product other than high price yacht stuff at £25 for 750ml ?
Thanks in advance for the help.
steve28
19 May 2003
Cornwall
www.falmouthgypsy.com
The only tip i can give you is apply the paint on a windless day. otherwise you end up with wisps of paint coming off the roller everwhere.
This only seems to be the case with blakes rubber based deck paint. it is however very good when used with the grit.
steve
marina95
16 Feb 2004
Me - Hampshire. UK Boat - Greece
www.bonzomedia.co.uk
I'll second that, the Blakes rubberised paint causes stringy bit flyoff mayhem!
The Blakes is inherently self levelling and if I were you I'd use a rotary sander to remove the flaky paint and give the rest a good key and then bung the Blakes on. My decks were in a similar state and I'm very pleased with the results.
Porthandbuoy
27 Apr 2003
The Gareloch
www.backbearing.com
Acetone is a definite No-No as it will dissolve your GRP (well, the P part to be precise). Which is one reason I never allowed my daughters to bring their nail varnish remover on board.
oilyrag
3 Jul 2002
E Coast UK
I used some stuff called Dilunett Gel Remover from the local swindlers. Splodge it on, leave it, wash it off - brilliant! Not cheap at about a tenner a litre but the time and effort saved over scraping is certainly worth it. I think they must lose a lot of business due to the name, but this obviously refers to it's consistency rather than it's intended use!
ridgy
26 Jan 2003
North West
That's funny, when I was fixing my keel last year I poured litres of the stuff in to the bilges (upon recommendation of a boat builder) to rid them of traces of oil.
Needless to say, no new holes appeared.
I think you'll find that acetone is very widely used as a degreaser in most forms of GRP repair work.
LaBaraka
25 Mar 2005
Hi,
I have successfully used a small waterblaster. Degreased with acetone. Quick wiping wont dissolve your GRP.
Walt
