Hi,
Last season I damaged a section of my mahogany carriage top and had to sand it back. It's now coming out very dark red.
Any advice in using a lightener to get to blend in?
Thanks,
Crisp
Some images below:
Desired finish:
Damaged area:
So well put ☺.It is not the cleaned bit that is dark, but the rest that has been bleached by the sun
Problem is you cannot get patches to match the faded areas. As soon as you remove the failed coating and sand it you expose the basic colour of the wood. . The only way for the OP to get his coachroof looking good is to deal with the cause of the water ingress at the forward end, strip all the varnish off the whole lot, restore the colour as best he can and then protect as suggested. Just one of the joys of owning such a boat and there are no shortcuts in the preparation. The good thing though is if you avoid "yacht" varnish and use the products suggested you can look forward to several years of light touching up only.I think the O/P is probably happy with the lovely silver tone that the wood has developed, rather not so keen on the "fresh appearance" of the damaged section but I could be wrong.
I was referring to the varnish coming off the corner post and the dark appearance of the front face - plus the gap between the side and the corner post. Looks very much like water has at least got under the varnish there, even if not necessarily into the boat.Many thanks for all the advice! Just to clarify there's no water ingress. The damage was caused by a loose section of cover blowing about that I had installed to protect the wood...
