gwingn
I need to replace ( on a Westerly Griffon ) my main hull anode and mounting bolts, unfortunately a previous owner has fitted rather nice stainless fuel and water tanks above the existing fitting so replacing a sheared bolt would mean removing the complete engine and both tanks to get access. I think my best option is probably to re-site the replacement anode a bit into a position allowing maintenance and I have a set of bolts with electrical connectors for that purpose.
Can anyone advise how such anodes are normally fitted? Is the the hull normally just drilled and the bolts fitted with liberal use of sealant or is it usual to drill and tap the (solid grp) hull?
Regarding the old fitting, given that I cannot get access internally to remove the bolts I'm wondering what the best solution is here. I don't fancy trying to drive them out from outside, particularly if they are tapped in, as there may not be sufficient headroom between bolt head and water tank to do so. One idea is to simply grind them off flush with the hull and then fair them in with a good lump of epoxy, another would be to use a hole saw to cut around both bolt and nut so as to remove them completely from the outside and then plug the holes - that seems wantonly destructive and a bit frightening to put largish holes in the hull.
