cmedsailor
I am thinking of adding a second fuel tank somewhere in the lazarette where I would simply transfer, when needed, fuel from that additional tank to the main fuel tank. As you can see from the photo my main fuel tank has simply the fuel supply pipe (after the fuel isolation valve) and the fuel return pipe (covered with some sort of silicone; was like that since I bought the boat and never touched it).
Do you think it would be possible to connect the pipe coming from the additional tank to either the place where the return pipe enters the main tank or probably a small distance before that? I mean to connect it to the return line with a Y or T connector? Would that affect the flow of the return fuel to the main tank?
