How tight are your mooring lines
PabloPicasso
12 Feb 2010
How tight do you tie your boat to a marina pontoon. Do you have lines tight and boat squeezing it's fenders, or a little slack to allow her to move a bit?
It depends. (Ok I’m talking Mediterranean stern to mooring) but without a passerelle the lines need to be extremely taut. Because the boat has to be close enough to step on and off the stern but not actually hit the pontoon. With a passerelle you can have lines that are slack enough for the boat to move about a meter.
I see some with the fenders squeezed half to death. Others with big metal springs on their lines,
How much of a thump can hulls put up with if your lines are slacker?
Slack, generally.
There's how I rig for stepping on and off, and there's how I rig for leaving her unattended for long periods or in foul weather. In the latter case, it's more of a preference for longer warps rigged on longer diagonals, and using springs and/or rubber dogbones to add further elasticity. My home mooring is very exposed to both wind and wash so I am quite sensitive to it.
There's a theory that shorter lines are tighter and reduce the shock loads because they don't let the yacht move as much. I don't believe that theory.
Then we have the really clever ones who seem to think that securing a shackle through the pontoon cleat with a bit of chain makes their boat more secure but in reality theirs is the first to break free.. I wonder why ?cleat.jpg
Then we have the really clever ones who seem to think that securing a shackle through the pontoon cleat with a bit of chain makes their boat more secure but in reality theirs is the first to break free.. I wonder why ?View attachment 111991
I'd also like to see the state of the cleats on the boat. I've watched boats trying to climb into pontoons in a blow; when that happens, I want a bit of stretch in things. I reckon all chain would rip the cleat right out.
Mine are put on tightish with rubber snubbers. They then slacken off after a day or so to the right feel !
Sounds a bit
S and M..................
|I would never use chain apart from a swing mooring.....it has no give.....
The ones with chain have around a foot of it at the cleat end, the rest is rope.
Pontoon cleats are usually nice and rounded and I've not seen any rope fail at the cleat end .
It's either snapped along its length or chaffed through at the boats fairlead. Not tying properly to a pontoon cleat also makes it less likely anyone will adjust your mooring lines passing by in violent weather as they are not going to board your boat to do it.
