Latestarter1
By comparison many old mechanical fuel pumps CAV DPA with hydraulic governing are no longer viable to repair.
Tell me about it! I have a good 'un and one that is suspect, but >£500 quoted to look at it and recalibrate if that's all it takes. Can, maybe, get a mechanical equivalent for less than that, but doubt its a viable replacement part on a drop in basis!
But there is also no (as far as I am aware) alternative and engine replacement is uneconomic. Despite the undoubted advantages of modern electronics there is no backwards compatibility, quite understandablly so, and therefore those with older engines will keep them soldiering on as best they can, happy in the knowledge that most trouble can be solved, or at least alleviated, with a spanner and a bit of knowledge.
In passing, why does it not seem possible to have the engine diagnostics feed to a screen that translates codes to language of choice and allows some form of user override? Limp home is OK for some situations, but mid Channel with a faulty sensor and the weather turning sounds like a lifeboat call when an "Ignore" button might have some equal validity, unless in warranty ofc![]()
I spend far too much time looking at motors which are way past their sell by date, too much time tinkering. Spoilt weekends and ruined holidays.
Somebody recently spent over 1K on the Lancing Marine smoke elimination kit for a a pair of very tired old Ford Dorsets, kits were worth any more than the engines they were fitted to.......... Leaky smokey old engines are often a complete money pit, not to mention the aggo and time associated tracking down obsolete and expensive parts.
I learned more than a few lessons from a friend who operated trucks in Africa (Zimbabwe/Zambia), he said I don't I even consider your old mechanical third world junk, I find trucks with electronic engines more reliable and durable. Pal operated over one hundred and fifty tractor trailer combinations with a mix of Cummins N14, Detroit Series 60 and some Volvo D12's, he made the switch to full authority electronic engines back in the late 90's.
Scenario with failed sensors etc does not paint a true picture. Remember when the RNLI are called out if it is a modern boat it will have electronic engine.
