rafiki_
New RNLI Shannon Class lifeboats under development....CAT C9's, many problems encountered during the long and intensive development phase of this vessel, engine issues, NONE! Two engines required regardless of being mechanical or electronic, classification societies do not differentiate, SOLAS have some batty outdated rules which are being re-drawn, twin engines in a rescue vessel just plain common sense...
I have made my view clear before that the use of of LDA (Light Duty Automove) engines operating a levels far cleaner than off road limits have no place in marine applications. Once again problems facing repairers of LDA diesel engines is:
#1 Our colleges turning out young people with inadequate skill levels, for years now they have been paid grants based on the numbers turned out, not the quality. Inability to understand the most basic mathematics is commonplace. The few good people become overloaded, whilst the numpties change filters and lubes.
#2 Major manufacturers have reduced the SRT (Standard Repair Times) to a level which makes the job of the workshop co-ordinator a complete nightmare.
#3 Take MAF sensors which do not/should not figure on marine engines, failure is in 99% cases caused by overfilling with lube oil, caused by the numpties in note #1 or stupid owners, another case of RTFM! High lube oil level causes oil carryover which in turn coats the MAF sensor reducing it's sensitivity.
#4 Fear of electronics due to ill educated and trained technicians (They are not engineers) means that they often start out on the wrong path. Typical example is low power complaint with hours spent trying to diagnose the problem with electronic diagnostic tools, as soon a a clear thinking tec went back to basics, ignored the electronic tools and put the gauges on, RTFM Simple restriction in fuel line due to disposable plastic glove ending up in the fuel tank, pieces eventually found their way into the fuel line.
Becoming paranoid by reading manufacturers fault code listing and making any judgement based on fault codes requiring replacement of ECM/ECU is plain nonsense. I currently have 18 new Volvo D12 ECU's which came along with a large batch of new old staock engine parts. Contacted Volvo dealer who checked useage, annually they sell a MAXIMUM of two into a truck market of many thousands.
Having warm cozy thoughts about a Perkins 4.108 is at best bizarre, when they were new they were always a poor substitute for a Mercedes OM636. As to being a taxi appication, yes they were approved retrofit to Fiat 124's for use in taxi conversions, never used in this country.
Sums up where this thread started, I can assure the poster that his modern Kubota based Nanni will still be running sweetly long after the 4.108 has cracked it's cylinder head for the n'th time. All based on a perception that old, crude and heavy is good, modern is bad. Not true.
Well said sir. In many cases ECU's are changed because it is easy, and looks like you have done something substantial, same in the auto industry. New ECU gets the engine going, while fault codes log up until it won't run anymore like the previous ECU. In cars, Ford was changing so many ECU's and finding no fault found when investigagted, so they made the ECU's extremely hard to get at and replace. Strangely the replacement numbers reduced, and the real faults were dealt with.
Modern engines, when used within their duty cycle envelope, and installed correctly, are very reliable. However, boat volumes are comparatively small, so manufacturers just don't do the verification on the installation, and the early buyers do the fault finding, relying on a good dealer to rectify.
Also, as LS states above, Graduate Engineers these days do not have either tha Maths capability of us old fellers, not the practical experience of keeping an old car going. We have to train our Masters Grads for 2 years before we let them loose!! At Ricardeo, we used to buy an old Mini, get them to strip down every nut and bolt, rebuild, and do and run to Italy and back. They soon learned mechanical empathy.
