How many Ah per day for Chinapscher?
B27
26 Jul 2023
As per title really.
I have a generic diesel hot air heater, how many amp hours should I expect to use running it for e.g. a couple of hours in the evening and half an hour in the morning?
fredrussell
24 Mar 2015
That depends on what speed fan is running at. Do you have it ticking over on low, or is it going full speed?
But generally speaking, for four hours a day it won’t be much. At a guess, one or two amp hours.
Plum
6 Jun 2001
UK East Coast
Spec for Eberspacher below, probably similar to chinaspacher:
B27
26 Jul 2023
Thanks all.
I think the 'off' consumption in the table is when the unit keeps the fan turning for a while during cool-down, that would make sense with the air flow quoted.
The control circuit seems to use a few tens of mA when completely idle, I've taken the fuse out because the illumination was a bit irritating at night.
I'll put 10Ah in the budget for an overnight.
It's time to be planning 'late season' jaunts!
fredrussell
24 Mar 2015
I beg to differ. I have measured the consumption of mine at nearly 4 amps, at full power, so that would be 10 AH for the usage the OP expects. Or 1/8 of my battery capacity.
I was thinking more of one operating at ‘tickover’ - about an amp per hour I think.
geem
27 Apr 2006
Caribbean
Surely the amount of current used depends on the volume of the space you are trying to heat. If the unit needs to run at high speed for a long time to get a high volume space up to temperature before dropping back to low speed then you will use considerably more power
  • Like
Reactions: jac
oldharry
30 May 2001
No, they dont usually have a thermostat. They just go n churning out heat at whatever setting you choose. They start at full heat during warmup. They do use a little more power at full belt obviously, as the fan is working harder. Some do have a preset temprature setting, but most people find it isnt sensitive enough to be worth bothering with. Mine just carries on churning out heat regardless! If you want a room thermostat facility you pay seven times the price and buy a 'proper' one from Eversplasher...
ProDave
5 Sep 2010
Alness / Black Isle Northern Scottish Highlands.
Mine must be different, it does have a temperature setting and the closer it gets to that setting, then the power output from the heater reduces and the fan speed reduces, so you can have it running at a low power and slow fan speed just to maintain the warmth.
oldharry
30 May 2001
Interesting. Mine does have a temprature setting, but it is so insensitive that its nto worth using: it willget far too hot befroe it switches off, and far too cold before itcomes back on again. Maybe something to do with where the sensor is fitted, but a with a t/stat worked pretty well - when it could be persuaded to stay lit, which wasnt too often!
plumbob
18 Oct 2009
Bucks
Interesting that there is consumption even when off, never knew that.
To get approximate Ah figure, multiply Watts by time in hours and divide by 12.
I have always left the programmer on. Didn't realise it has much of a drain on supply. Excellent item but needs a main switch.
wingcommander
25 Jul 2013
Glow plug also kicks in on turn off . To reduce carbon build up . Mine tested with clamp meter measures 9 amp on switch on / and off . Only for a minute then drops to 1amp during normal operation.
B27
26 Jul 2023
Up to a point, but a small boat in England, I think we will be at least cracking the hatch open a bit, if not sometimes running it flat out with the washboards out to drive out some damp.
Thanks everyone for the information, looking back on my notes from last year, I was probably either starting with a 'not fully charged' battery, or I need a new house battery.
geem
27 Apr 2006
Caribbean
What's a definition of small boat? Average size in the Caribbean is about 45ft. 'Small' isnt an SI unit😄
lustyd
27 Jul 2010
It's not supposed to have a main switch as that risks someone unwittingly switching it off before the cooldown sequence is done which best case might damage the unit and worst case could cause a fire.
