pottyYachtie
I have a 30ft Steel boat fitted with a cruising chute, how do I work out how long a spinnaker pole to fit?
The one problem with a Telescopic pole is the weight and the cost.
Although quite what you need a spinnaker pole with a cruising chute is a little baffling...
I made my telescopic whisker pole from a B&Q TV pole and a rotary washing pole, the diameters were just right for one to slip into the other.
Plastic piston ends and locking pin from Force 4.
Cost me about 30 quid![]()
I agree with GoG and Bignick, your CC should be flown off a strong bow fitting with a block and a tack line back to your cockpit for easy adjustment.
