How long a Spinnaker Pole?
merlin3688
6 Oct 2011
Brightlingsea, Essex
www.sailingschoolandrigging.com
Telescopic Pole
I made my telescopic whisker pole from a B&Q TV pole and a rotary washing pole, the diameters were just right for one to slip into the other.
Plastic piston ends and locking pin from Force 4.
Cost me about 30 quid ;)
I supply 21/4" and 2" tube that slide nicely inside each other however it alway has been a problem with how to lock them in position, some on the market have many holes that give you loads of adjustment however I think
you probably only need 3 or 4 settings, out, 3/4 out, half way out and in. When its at its smallest length it is easy to store below deck. If anyone could come up with a simple locking system telescopic poles could be so much cheaper! The one problem you cannot get away from is the weight, especially on the larger yachts.
I think Telescopic poles are more suited as Whisker poles, diamater of poles can be smaller and you do not have the loads on the side of the pole when reaching with the Spinnaker pole against the forestay.
