How does hydraulic furling work?
goeasy123
10 Nov 2018
On a biggish yacht with hydraulic genoa and/or mainsail furling where does the pressure come from? Do you have to have an engine running all the time?
Not very helpful, have you been drinking?
Misery !!!
No, I have NOT been drinking. I have just returned from a 3 hours session at the dentist. But inspite of that I thought that I could still try to add some humour to the thread.
Sorry if it was wasted on you.:rolleyes:
I will have a quick glass of scotch though, cos you will probably be pleased to know that it b..y hurts in the mouth AND the wallet :(
NB
Emojis with HA HA will NOT be appreciated
On smaller hydraulic systems an on-demand pump as mentioned above. The switch activates an electric motor which directly powers a small hydraulic pump (example: autopilot, furling gear).
On the very big yachts, the hydraulic system is usually permanently running as a constant running pump has advantages in these applications. So these ones use a larger motor and pump which is always running and developing pressure, the pressure is 'dumped' back to the reservoir when not needed and a series of valves will divert the pressure through the system as required (example: stabilisers, superyachts).
Some of the larger systems may develop hydraulic power from an electric motor, or via a PTO (power take off) from an auxiliary engine or genset. Engine driven is unusual on smaller hydraulic systems, but common on larger ones where more pressure is required (example: fishing / large commercial vessels).
