lenseman
- Joined
- 3 Jun 2006
- Messages
- 7,077
- Location
- South East Coast - United Kingdom
Looking at the photograph that VicS has put up for you, it looks like someone has tried or has successfully removed the top washer by using a cold chisel. You could try firstly with a Gas-pipe wrench or failing that, another cold chisel. Cold chisels are fairly destructive that is why I suggest using it secondly! /forums/images/graemlins/shocked.gif.
Now, looking at the spindle nut, I suspect that this nut is at least 1" or slightly larger as it would have to be tightened enough to make sure that the wheel did not fall off in use. I further suspect that this nut actually tightens the spindle 'onto' the leaf-spring such that there is no actual movement between the nut, spindle and leaf-spring?
That said, I think that you basically are just not applying enough torque to loosen this nut. Nuts of this type and size are probably tightened to anything above 100 foot-lbs possibly as high as 150 foot-lbss!!
Don't even ask what that might be in Newtons per Hectare, if God wanted us to go metric, he would have had ten disciples. /forums/images/graemlins/grin.gif
Joking apart, I think that the garage used an Air-Impact wrench to loosen the nut and if you live close to Crawley/Reigate in Surrey you can come and borrow my Snap-On air-impact wrench.
/forums/images/graemlins/smile.gif
