How deep does your depth sounder go?
Porthandbuoy
27 Apr 2003
The Gareloch
www.backbearing.com
Simple question. On my current and previous boat the depth sounder seldom read deeper than 30~40 metres. Boat one transducer was mounted in an oil filled tube in the hull. Current boat has the transducer mounted through, and faired into, the hull. I expected the second one to read deeper.
michael_w
8 Oct 2005
On my old boat the Garmin 160 C fish finder would reach 350m. The new boat has had another Garmin fitted, but as I've only sailed her in the southern North Sean and the Channel I don't know how deep this one will go.
Praxinoscope
12 Mar 2018
Aberaeron
On my previous boat I remember the Raymarine ST50 becoming a bit erratic at depths over about 100m my current boat has an Raymarine ST 40 depth sounder, but have never sailed it in a greater depth an about 50m at which it still seems to work, but don't know how much deeper before it gives up.
Refueler
13 Sep 2008
Far away from hooray henrys
If it'll reach 1000m, it must be a pretty beefy bit of kit. The power required goes up as the square of the maximum depth, so a sounder capable of reaching ten times the usual range of a yacht's echo sounder should use about 100 times the power!
I would not even expect a ships sounder to reach 1000m !! But I did use a 500m line of West Africa ....
PetiteFleur
29 Feb 2008
Suffolk
I remember on my previous boat, I suddenly had a shock when it suddenly started reading 2.5metres, consulted the chart and I was in 20 metres plus, confirmed with an ancient lead line. The depth sounder had moved the decimal point after 20 metres! Can't remember the brand though.
vyv_cox
France, sailing Aegean Sea.
coxeng.co.uk
This happens with ours at a specific depth, about 90 metres from memory, when it will suddenly display less than 10 metres. It is caused by the receiver 'hearing' the previous discharge rather than the immediate one.
The B&G Triton instrument reads to 130 metres mostly but sometimes will go higher.
Mudisox
4 Jan 2004
Dartmouth
Much depends upon both the substrate of the seabed and also the speed/ movement of the boat. My cheap one can detect the Hurd deep, and enable to detect crossing/keeping to 50/20/10m. It also will enable depth anchoring/ taking the ground.
LittleSister
12 Nov 2007
My depth sounder goes down about an inch below the hull. 😁
But you have to remember that metres are not as substantial as proper British fathoms, and so the signal probably passes through them that much easier. ;)
Anyway, who'd care about the power requirements if the alternative was using the lead line in 1,000m/547 fathoms? :D
