rich201283
How can i detune a peugeot 1.7d xud??
hi
thats what i mean i would like to reduce the power.
On that type of engine the throttle controls revs i.e. max power. A
So to answer the original posters question get a diesel injector pump shop to reset the maximum fuel stop to a lower level and you will have less power with the same RPM limit. .
Is this the same as the stop on the throttle linkage?
Yes and the poster hasn t thought about his reply before posting
GDARFC
Err.. Provided the engine in question has a mechanical injector pump, I would say "No", and would agree with TQA's reply.
Throttle linkage sets speed on diesels. Governor determines fuel, up to the max fuel limit.
Please explain if I've fallen into some trap or other
Andy
Peeps should have asked why do you want to limit the power. Then they could answer the question. But if you are fitting it in a boat, it then it begs the question why instead of a marine diesel, then if the answer is cost, then most of the answers, ie messing with injector pumps on a test rig negates the savings.How can i detune a peugeot 1.7d xud??
With respect Stu, not opening the throttle is not a good solution. You end up with a very limited range of throttle to use. In my case, with a 55hp in a 12m, 8.8t sailing boat, at 800rpm idling it does 2.5 to 3kts, 1500rpm 6kts, 2000rpm 7.5kts. With more power at idling I would be doing 4 to 5kts and hull speed at somewhere near 1200 to 1500rpm. You have to loose power somewhere else and it will become uneconomical.If you worried about the engine being too big for the boat in terms of output then dont open the throttle, as siggested by others!!
Stu
