prv
I think the argument would be that the cable is securely mounted to the starter and so very unlikely to come off. Adding a fuse simply moves the potential for a fault along the cable a few feet, to where the battery cable is connected to the fuse. So actually it probably doesn't result in a system that is any safer.
The fuse in the battery compartment is not surrounded by lots of metal at earth potential.
In my case, the link from positive post to fuse is about an inch long (two ring terminals back to back) so cannot reach the negative terminal whatever happens. The only way to get a short would be to open the battery box and add an additional piece of metal.
Since the most likely "additional piece of metal" is a spanner, I have a dedicated battery spanner which is wrapped in insulated tape over its whole length except the business end.
