Hour meter readings
russ
9 Nov 2009
North East Hampshire
I know the Volvo hour meters have reliability problems. If they were renewed previous to my viewing the boat would they retain the hours from something else its wired through or are they zeroed as being new?
Reason being, a 14 yr old boat with 190hrs and worn outdrive steering fork joints doesn't seem realistic to me.
jwilson
22 Jul 2006
AFAIK all the Volvo and Yanmar combined tacho/hourmeter instruments (the ones where the little LCD usually goes blank after a few years) read zero again if a new instrument is fitted.
volvopaul
1 Apr 2007
midlands
hotmail.co.uk
Doesn’t sound realistic to me .
No hours stored on the 41 engine as no ecu .
oldgit
6 Nov 2001
Medway
There are a number of companies which supply various kits to replace the hours display on older style tachometers if it is digital.
Some are simple to fit and some need a bit more skill.
Also a Youtube video how to do the job.
They seem to suggest the hours are stored elsewhere in the Tacho PCB and the total hours run will be on the display after the repair.
"This screen replaces faulty / blank LCD screens in the Volvo Penta tachometers.
The hours are logged in the instrument, so even if the LCD screen is broken the hours are still recorded. After changing the display, your original engine hours will be displayed."
https://www.ebay.co.uk/itm/Volvo-Pe...828792&hash=item5b5320c0f1:g:W5gAAOSw0dFcYfUh
https://www.yachtboatparts.com/volv...3992---vp873688-vp873660-or-873998-8003-p.asp
https://www.youtube.com/watch?v=PFkSwD5-mfw
think the steering fork joints are supposed to be replaced every few years. ?
Momac
7 Feb 2008
UK
Low hours does not equate to few defects.
Lack of use and associated corrosion and lack of annual maintenance may lead to defects despite low hours.
Bbroomlea
13 Oct 2010
House - Teesside, Boat - Windermere!
Only recently have the replacement Volvo screens been fairly readily available in the UK that hold the original hours, before that it was direct from Sweden only.
Before this there was a fix but it zero'd the hours and was only useful for season to season servicing.
It was possible with the old screens, if the hours were known, to match the hours leaving the tacho connected to a 12v supply until they caught up - but why would you do that???!!!
Greg2
24 Jun 2002
The hours are stored in the tacho and the LCD display is just that.....a display. I replaced the LCD displays on our S34 recently (KAD32s) and they display the actual hours run as opposed to starting from zero.
oldgit
6 Nov 2001
Medway
Which repair kit did you use ?
One of my Tachos needs sorting and trying to summon up the enthusiasm to do it even though have all the tools and equipment at work ready and waiting.
Momac
7 Feb 2008
UK
However the displays that retain the hours have only recently become available.
In this case the displays may have been replaced some time ago and not adjusted to reflect the true hours. I suspect this may well apply to many boats as the hour counter issue is very common.
I make a note of the hours from time. If the hour counters should fail completely I will have a very good idea of the true hours.
In this case perhaps the present owner of the boat could be asked whether the hours showin are true.
Greg2
24 Jun 2002
Seabridge do two types - one is cheaper and involves some slight modification and the other is a bit more expensive but is a straight swap. I bought the second one - well I actually bought the cheaper one at first because I didn’t know about the second one until I read about it on the Sealine Forum - Seabridge were very helpful and did a swap https://www.seabridge-marine.com/index.aspx?pageid=2023674&chainID=219000&txtQuickSearch=Hour+meter
It is a very easy job to swap the meter out.
Greg2
24 Jun 2002
Not sure I understand - the hours aren’t stored in the LCD display as far as I am aware - it simply displays the information that is stored in the tacho. Both replacements I describe in my reply to oldgit achieve the same thing i.e. they display the original/genuine hours. The one we ended up with is the one that has become available more recently but the other has been around for a while and Motorboat Owner did an article on them a while back.
jrudge
4 Dec 2005
Live London, boat Mallorca
Accepting that some don’t have ecu I wonder if for example mine - evc a - pick up the hours from the can bus. The hours on the taco and the plotter are identical and the odds of that over 700 hours tocthe decimal point is nil unless the same value presented twice
oldgit
6 Nov 2001
Medway
There would appear to be 2 different sizes of LED hours display shown in various online pictures.
Assume the "smaller" hours recorder is in the older/earlier Tacho as fitted to my 1991 / 41B and the larger unit to later boats fitted with KAD 42/44/300 engines.
Or just an optical illusion. ?
Momac
7 Feb 2008
UK
Not sure I understand - the hours aren’t stored in the LCD display as far as I am aware - it simply displays the information .
For whatever reason the replacement displays used to start at zero.
Perhaps the replacement displays retaining the hours is not as new as I thought.
Bbroomlea
13 Oct 2010
Maplin used to do a replacement LCD screen that would fit with a bit of doctoring which didn't retain the hours. I replaced the screen on my old S24 and I added 300hrs using a 12v battery so they matched.
