steve yates
Anyone ever tried that? Can you get something like with narrow enough attachment to fit down the filler cap?
A pressure pump, normally used to extract oil from the sump, but equally good for your job or cleaning oily bilge water. Very common bit of kit available from any chandlers.
What's a pela tranona?
[pedant]A vacuum pump, actually![/pedant]
...... or is it atmospheric pressure which actually does the work?![]()
One thing to beware of if trying to pull muck through a Pela sucker is that the narrow metal-wound dipstick tube is fairly easily blocked by solid matter. If I was going to try hoovering a diesel tank with one, I'd probably swap that part for a length of slightly wider copper tube.
