doughnut
I've taken out the sea toilet and am replacing it with a portapotti. The toilet is out, the pipes are removed and all I need to do is remove the hose connectors from the seacocks and replace them with blanking plugs. The inlet hose connector unscrewed easily, no problem. The outlet hose connector (1.5 inch) is solidly jammed in. I've spent about 90 minutes trying everything to budge it, but came away from the boat because I was getting tempted to get the big hammer out and I might have some regrets later about that.
Anyone got any tips on how to loosen it? I guess the alternative is to try to blank the outlet hose connector, or even just attach a long bit of pipe leading to a high point.
I didn't want to but I did try to remove the seacock from the skin fitting for 10 mins but thats stuck as well. I'm ok with that being stuck as long as I can blank things at the hose connector end.
