Dutch01527
I recently bought a MacGregor 26X despite reading all the warnings on this and other forums. I thought that it might be interesting to share some observations.
Good Points
- Flexibility. We live in Worcestershire next to the River Severn. We have a pontoon on the River and use the boat as a motor boat when at home. We have also had long weekends away sailing in Windermere, Cardiff, Milford Haven, DartMouth and Salcombe in the last two months
- Interior space
- Low draft for creek crawling and beaching
- Easy to sail and maintain
- Safety - yes safety- it is foam filled so unsinkable and rights it's self if knocked down. This assumes that the water ballast is full which it always is when my boat is not on the trailer. I know I that the need to fill the ballast is cited as a danger because it can be forgotten but I do no understand that thinking. Any boat is dangerous if you forget to close the hatches, isolate the gas, reduce sail when needed, check the rigging / weather /charts etc. It also has a 50hp engine and a 5hp auxiliary that make getting out of trouble easier and quicker
- Reasonable sailing performance - I do not claim that it is good but it is not bad. Last week we were sailing off Dartmouth / Brixham in about 12 to 15 knots and a gentle sea state. We maintained 4 to 5 knots close hauled at about 45/50 (apparent) degrees and 6 knots running downwind. Not going to win any cups but enough to enjoy the day. That is comparable with a bigger, heavy displacement yacht such as a Tradewinds 33 from memory.
Bad Points
Ugly - can not be denied that it is not a beauty
Light and loose rigging - I am half way through upgrading the rigging to make it stronger and more adjustable. The base set up is much too loose imho because of the need to step the mast frequently. Adding turnbuckles, adjustable back stay and boom vang has made a massive difference
Cheap finish - corners have been cut to save weight and cost but nothing that a bit of DIY will not fix
Restricted range - I would not take the boat away from the coast. It is too light to risk a major weather shift. I had it out in a unexpected force 6 gusting 7 in Cardiff Bay for an hour (no waves) and it did not feel dangerous it was just almost impossible to sail effectively albeit I was over powered and was not happy to reef because I was solo and my furler was faulty.
In conclusion it is the wrong boat for extended cruising, racing, ocean crossing or keeping in one local location.
However, it could be the right boat for people with limited time who want to enjoy day sailing in many glorious locations.
Just for he record whilst not an expert I am not new to sailing/boats as seems to be the common perception of MacGregor owners. I am a ex Merchant Navy Officer with 30 years of sailing experience, mainly as racing crew coastal and offshore.
Good Points
- Interior space
Bad Points
