Hopefull Vendor
Tranona
10 Nov 2007
Yes Forty Featherweight with Wipac magneto and brass tank so probably pre 1977. With Villiers carb can be made to run on 25:1 with correct needle. Looks superb!
VicS
13 Jul 2002
With the Wipac Mag post 1967 ??
Pity the original plug cap is missing.
As you say can be modified to run on 25:1 Mine does. so does my 40+ ...both with bronze flywheels and Wipac mags
Pre '67 had silver Villiers flywheels . Generally not advised to run pre 67 ones on 25:1
Tranona
10 Nov 2007
With the Wipac Mag post 1968 ??
Yes - thinking about it probably pre 1976 when the Bing carb came in, and the nasty steel tanks - but could perversely be later as I recall making some "classic" models with all the old bits to use up stock in around 1979/80 when the "blue" engines were coming on line. Prompted partly by finding several thousand sets of brass tank bits buried in the back of the stores and a huge stock of 3.5:1 gear sets as used in the Century and 40Plus. sold 2000 Centuries to the Dept of Fisheries in Malaysia in 1979 - good price as the order used up loads of otherwise obsolete stock. Happy Days!
Sneaky Pete
26 Nov 2009
In the shadows of Faslane.
Hopeful vendor
Is this person in marketing but hoping for a career in politics? Why is it that when advertising the vendor usually says “very good condition as seen in the photos” I always believe that seeing the item in the flesh will make your mind up as to its condition? Photos just give you a taster. Which would be the prefered buy, very very clean but doesn’t run or runs perfectly but has a few scuff marks?
See other ad
http://www.ebay.co.uk/itm/NEW-marin...641?pt=LH_DefaultDomain_3&hash=item27c2c2b481
Is this classed as new?
