Honfleur and St. Vaast
ricsearle
16 Aug 2004
Hamble, UK
ricsearle.com
Hi,
Can anyone tell me (with a reasonable degree of confidence) what the lock-opening/bridge-lifting times at Honfleur (vieux port) are at this time of year? I'm popping over there around 17th-21st Feb, and I can't find much information about the off-peak season.
I'm also considering a visit to St. Vaast, but I have a deep draught (2.3m). My almanac says that the inner basin in maintained at 2.3m, but other sources seem to differ. Does anyone have a more accurate observation to help me save a little embarassment?
Thanks, Ric
Redmond
29 Oct 2003
London
I draw 2.2 and have no problems as long as I wait half an hour after the gates open in St Vaast. There is a rock about 10 meters inside the lock which we have just caught and seen others catch.
Skysail
30 Sep 2004
Victoria BC
St Vaast gets shallow ie 1.6 m or less the further in you go; with a draught of 2.3m you could berth with the bigger visitor boats on the first pontoons to starboard, which should be no problem. I expect it will be empty at that time of year and the HM will be helpful - why not contact him, the St Vaast website is v useful.
brianhumber
30 May 2001
Sussex
Lock is 24hour operation and works on the hour and half hour.
with your draft I would be thinking 2 hours before local HW for poodling up the river
Inner bridge opens in the morning in winters
BUT
its winter and you should check with the HM for maintenance work disruption.
St Vaast - keep to the first couple of Pontoons to your right after gates or you will bottom before the gate closes - gets shallower as you go further into the Marina
milltech
31 May 2001
Worcester
www.iTalkFM.com
I used to get 2.4m into St. Vaast no problem, get close to the harbour office, hard right turn on entry. Worth phoning if your language is up to it.
