Honda inflatable, I thought to ask here first.. because peeps are generaly helpful.
Tomahawk
5 Sep 2010
Where life is good
I have a Honda inflatable with an inflatable deep V floor. Works very well as you inflate the floor to a much higher pressure than the big tube and the floor becomes very rigid.
However the valves are leaking where the are sealed to the material of the inflatable. Not the actual valve themselves, but round the edges of the plastic fitting.
Anyone got some experience and how to fix? I don't want to start by poking about incase I make it worse.
GrahamM376
30 Oct 2010
Swing mooring Faro
Assuming the Honda uses standard valves, you need to tighten them up with a valve spanner/key. Deflate and hold the backing nut through the fabric and tighten the valve with the key. Edit - make sure you have the right key, there are several types, 6 or 8 segment etc.
