steve66
Watch this space...... I have a meeting with a guy who may be making me tooling for stainless float bowls and stainless rocker covers.
They are only coppers to buy. If anyones interested in swapping you will need for the clutch and engine,
3 x m6 x 25mm flange bolts
4 x m6 x 60 bolts (usually the original washers are ok) DO NOT PUT LONGER BOLTS IN ,YOU WILL PENETRATE THE LOWER CRANKCASE COVER!!!
Other critical bolts that tend to rust are rocker cover and exhaust manifold bolts.These are m5 x 16mm flange, 20mm will be fine.
Hope this helps someone
http://www.ybw.com/forums/showthrea...l-even)-for-Honda-BF2-3&p=4979544#post4979544You wait until your carb rusts out, blocks all the jets with crud, and see if you still think it's a good engine. What can anyone possibly like about that nasty rubbery flap that holds the cowl on rather than the clips Yamaha use which must have cost an extra 50p? Tried draining the carb with the drain screw? Bet you can't because there's a furball of rust around it. Cheese metal bolts which can be replaced for buttons is just sloppy. A carb that rust which is expensive to change is absolutely unforgivable and the only explanation I can think of is that the designers had zero experience of materials in a marine environment, or more likely, the bean counters ruled the show.
They are the nastiest most penny pinched marine engine going and are a disgrace to Honda's previously good reputation. The Honda dealers know it's krap. They must have given feedback up the line. I can't understand why Honda persists with it rather than ditching it and replacing it with a decently made new model for another £50.
have you tried a s/h lawnmower shopI'd be interested in one of them now!!
maybe somebody can replate them?
Hence binning it & buy one made by Tohatsunot yet, but thats a good idea.
Steve66 pointed out the electrolysis issues here. ANY moisture that gets to the carb sits at the bottom of the bowl, where we have, in close proximity.
a mild steel, zinc coated bowl
a mild steel male thread in an aluminium female thread for the bowl fixing
a brass /bronze drain screw (seized)
with such a cocktail rust is surely inevitable.
The usual advice about draining the carb is good, not for the usual reason of preventing the varnishy products of evaporation of the fuel, but to prevent the rust, so I wish I had followed it.
ReallyI suspect the Honda 2.3hp is the same 57cc engine as the Honda 57cc lawn mower one. Nothing wrong with that but....for the fact that patently no attempt was made to marinise it by using the right materials. Probably taken from the garden machinery parts bin, popped on top of a central fugal clutch (no doubt from the moped parts bin) and bingo - cheap engine to produce.
I remember the "drain screw" on the carb on the one I had. Big contrast to a 40 year old villiers carb where it was all high quality brass and alloys. The seagull villiers carb is about the most robust simple durable carb ever - very very crude and leaky - but always serviceable.
I recall the moped clutch was oil soaked, whereas that in the BF2.3 is dry, so I think not.
Well they make better lawnmowers than outboards thats for sure.Hi all, I contacted Honda Marine UK, and gave them a link to this thread. They have promised a response - so watch this space!
For the best small outboards Tohatsu & their re-badged models take some beating
Im a member of the Honda community for small outboards run by Honda uk. I have asked question after question and the answer i always get is we have forwarded this to your local Honda main agent. They will be in touch shortly. The local agent is a very good friend of mine , still waiting for my responsesHi all, I contacted Honda Marine UK, and gave them a link to this thread. They have promised a response - so watch this space!
In my view this is predictably defensive, but perhaps also acknowledging that there are concerns they ought to be listening too.
Of course this is a response from Europe, not Japan where the bosses are.
