Honda BF 2 and 2.3 - a few observations from a long term owner
dylanwinter
28 Mar 2005
Buckingham
www.keepturningleft.co.uk
I have owned three of these and used them on at least 15 different boats from a flub dub to Katie L at 22 feet.
One I sold with a boat, one jumped off the bracket (Honda have now improved the clamping arrangement) and the third is still going
however, that does not mean they are perfect
silver-fox
3 Apr 2006
Sicily
yacht.silverfox.googlepages.com
I too am a Honda fan but disappointed at the same corrosion you experienced.
I bought mine as a package together with a Honwave Aerodeck 2.7 inflatable which had a problem too with some eyelets corroding badly. Honda UK were brilliant arranging for me to collect a warranty replacement in Mallorca and the problem has not recurred. The design and tube size of the inflatable make much more buoyant and drier than most and I have been delighted with it.
7 years on I am thinking of getting a bigger outboard to get us up on the plane when laden - maybe a 8 hp - but I am a bit wary of Honda now, whereas last time I simply trusted the brand.
So my message is the same as yours but maybe a little blunter.
Honda, you have a hard won reputation for well designed durable products and customer service. The 2.3 HP outboard is not up to your normal standards and damaging your reputation. It is simply too prone to corrosion to be used in a saltwater environment.
dylanwinter
28 Mar 2005
Buckingham
they are fantastic little engines
but
"there but for a haporth of tar"
I gave up on the bolt and took it to my car man mark
he pulled them out in return for a bottle of wine
good man
he said it was a pretty poor show - one of the bolt heads was really badly corroded
incidentally, two of the four rust, two are not nearly as bad, so I assume there is something galvanic going on
D
D
sailorman
21 May 2003
Here or thertemp ashore
but
good man
D
D
They are brilliant engines, IN A LAWNMOWER :encouragement:
AngusMcDoon
20 Oct 2004
Up some Hebridean loch
You may like them, but I think they are expensive shoddy rubbish. It's not just those bolts that rust, loads of stuff rusts on them because they have penny pinched. Here's what happened to mine...
- Fuel cap leaked allowing water in to the fuel. Replaced it.
- New fuel cap still leaked allowing water into the fuel. Couldn't drain the carb because the outside of the float chamber had rusted and the area around the drain plug had turned into a rusty furball. Unbelievable that the float chamber is also made of rusty steel. Not surprisingly, all this made it a pig to start. Sometimes dribbling petrol into the cylinder was the only way to make it go.
- Water in the fuel rusted the inside of the float chamber on the carb. This caused bits to flake off and partially block the jets meaning it would run only with the choke on.
- Tried to remove the carb for an overhaul - couldn't get it off because the bolts had rusted and seized solid.
- Traded it in for a Yamaha. Got £100 for it. I reckon that engine cost me £50 per hour to run.
The Yam might be a bit heavier, but all the bolts are stainless, and I will never have to fight with the Honda's stupid badly designed awkward finger trapping shyte fitting useless rubbery cowl catch designed by Scrooge himself (can you tell how much I liked that feature?) Honda, I will never buy anything you make ever again. Pity. Everything else has been great.
dylanwinter
28 Mar 2005
Buckingham
the lawnmower has been faultless
as was the moped, the car and the chainsaw
the lawnmower has been thoroughly abused over the years and comes back for more
the engine on the outboard is marvelous - starts every time, runs on tickover without choking on its own grunge, runs at full blatt all day without overheating, very fuel efficient
does not suffer from sucking weeds into the cooling system
noisy of course
but......
they could do with upgrading a few bits and bobs on it
D
sailorman
21 May 2003
does not suffer from sucking weeds into the engine
but......
they could do with modifying a few bits and bobs on it
D
a mate had one of the first honda 2hp motors it was replaced under warranty due to rust, nothing has changed in the past 15 yrs has it
Tintin
21 Mar 2009
Kernow
Well I am loving my Honda air-cooled - saying goodbye to water cooled woes is great, and actually people say they are noisy, but it is no more than my old 2hp 2 -stroke.
Any thoughts on what to coat the bolts in to stop the corrosion? a bit of hammerite? Or some grease? Or zinc paint?
sailorman
21 May 2003
YES
Why dont Honda do it in the first place
Talulah
27 Feb 2004
West London/Gosport
I've had three Honda 2/2.3.
Each time the protection from the elements had been slightly improved. Bigger plastic covers etc. However, they never corrected the fundamental flaws.
The corrosion on the last one was the last straw. Now switched to Suzuki. Too soon to say if it was a good move or not.
But Honda should be in no doubt that their brand in my eyes is severely tainted.
sailaboutvic
26 Jan 2004
Northern Europe
Funny when I complained about my Honda 2.3 some years back , when I couldn't get part for the gearbox , Main agent Honda Greece wanted money up front and said it could take some months before they could get them in because Honda was very slow in parts delivery , Honda dealers in the Uk none seen to have the part and couldn't tell me when they could get it , has it may have to come from japan and Honda UK was a totally waste of time didn't want to deal with me and kept telling me to go to one of there dealers , but everyone on here through the Honda outboard where wonderful and if one dare to talk about Honda , you commented a sin . I see people views have change , on the other hand we had the same problem as Angus almost since new , but it still running , but only because it has loads do maintenance each month.
I wouldn't buy a Honda outboard again .
www.bluewatersailorcroatia.webs.com
dartmoor
27 Sep 2011
I had one - rusted badly - but ran faultlessly whilst I had it. Fundamentally what it has going for it is that if you have to adopt the evils of a four stroke, it is air cooled and under 13 kilos. For less than 4hp power in marine environment, air cooling avoids so many issues and problems. Interesting that really ancient Tomos's and Yam 3.5's are still fetching good prices. Why? Because some people absolutely don't want the issues around salt build up and replacing impellers.
AngusMcDoon
20 Oct 2004
I agree it is a good idea but in the BF2.3's case it has been badly executed and sullied Honda's reputation. If Honda had spent a little bit more it would be an excellent engine. Yamaha can make a decent product at that size for £50 more. I'm sure Honda could have done so too.
dartmoor
27 Sep 2011
Yes, it does smack of complacency by Honda - due to lack of a competitor doing an air cooled small light outboard, and the fact that people still buy them in numbers. Only hope is that the Chinese continue to improve year on year on quality and in a few years time come up with something marketable, very good, and at a cheaper price. That would provide the much need wake up call to the Japanese suppliers!
ghostlymoron
9 Apr 2005
Shropshire
Take them off and replace with stainless. Grease the threads.
