Honda 8 again
lexi
28 Feb 2006
If anyone remembers previous thread........my apologies /forums/images/graemlins/smile.gif
What effect would a partially blocked (deformed at exit Crankase breather tube have on running. I will try this out next time out on water .
Alex
When I had a car crankcase breather blocked (totally) it seemed to run OK but pinked like crazy under much load.
It depnds how restricted it is I quess. Can you disconnect it to see if it makes any difference.
Thanks guys
I will run it and cover or block the breather to see if I can replicate my problem. It may be Red Herring. Have put a Biocide through system Any other ideas appreciated. Bear in mind engine ran for two days last time out befoere stalling under load again.
Alex
I
Alex
[/ QUOTE ]#
If enough pressure develops you will blow the oil seals out. Major dismantling to get to them to replace them usually.
Otherwise a bit of power loss as mentioned.
