phil4383
Hello, yesterday I ran my Honda 2.3hp briefly out of water. It started second pull and ran for about 30 seconds with the prop spinning before coughing and stopping. The motor is new to me and as it is air cooled thought it should be fine but have now become aware that I shouldn’t have run it out of water.
It wouldn’t start again so I gave it a routine service by
- cleaning the carb (bowl and jets)
- An oil change
- gear oil change
- cleaned the spark plug and checked the spark.
Now I gave the motor a pull and nothing happens. It feels as if there is no compression. I took the puller off and it works fine and turns the head wheel (not sure of proper name).
The motor pulls very easily and gives a little wining sound that makes you think that something isn’t right and it certainly won’t fire up.
Should the prop turn a little whilst pulling? I can’t remember. It doesn’t anyway.
Any ideas would be greatly appreciated.
Many thanks Phil
- An oil change
- gear oil change
Many thanks Phil
