drew silverwitch
Having just had a tank fitted what would you recommend putting in it to stop smells and help break stuff down
And based on another recent thread, I am guessing there is nothing we can do to prevent the build up of calcium ( a pee/sea reaction I think), other than manual scraping etc???
You could use a fresh water flush, which is impractical for most people. Or minimise the amount of seawater used by simply pumping urine out of the bowl without flushing; we do this routinely and have had no problems with the holding tank. We flush the bowl lightly now and then with fresh water using the hand-held shower.
Odourlos does both the things you ask
Ours are about 18 years old now and very heavily used for the 10 years before we owned it. We change the pipes every 3 or 4 years as the smell eventually seeps through. Apart from the first time there was only minimal calcium build up. I put down a bottle of vinegar once or twice a year.
We tend to only have contents in for maybe 3 days at a time before we are out to sea again and flushing through plentifully.
I have been using Elsan Blue which is very effective at killing odour from the loo but a bit toxic to everything living and I am bit surprised it remains available.
