holding tank pump
kdf
30 May 2001
I need help with a holding tank pump - its a self priming Jabsco unit but when you push the buttom to pump the macerator appears to be working but the pump never really engages. Is it possible that air is leaking in an preventing it from priming properly? Is there a way to manually prime these?
thanks
Aeolus_IV
24 Apr 2002
East Sussex
Expert advice at hand?
I suggest talking to Jimi - he's now a forum recognised expert in all things related to holding talks.
/forums/images/icons/smile.gif Jeff.
MLBURGE
24 Jul 2002
medway
Is there a change over valve to select mac pump out and deck pump out if so is it in the correct position. If so you can select the deck outlet position and pour some water in the deck fitting then change the valve to mac outlet position and this should get the pump pumping.
This was a necassary task to do on one boat i know of to get the pump pumping.
kdf
30 May 2001
No theres no change over valve - may be something I need to fit. Jabsco say the impellor may be gone.
David2452
6 Jun 2001
London & Fambridge
Jabsco are probably right, if the pump runs and nothing happens it's almost always the impeller on the macerator pump or a blockage upsteream of it.
David
