fredrussell
Double post.
No, have a good read of it. Op seems to be very knowledgeable in this area, and has the equipment to provide actual figures. It’s a long and tedious thread I’ll admit, but what I take from it is that the American boating authority has picked a class T fuse as the best fuse because it’s good enough for pretty much any size battery bank one is likely to have on a boat. But if your battery bank is a ‘smaller’ one, you can use certain other fuses such as MRBF safely.But isn't that just a forum post by some random bloke ?
The general thinking is that Class T or NH fuses are best practice. Even the best midi fuses only have an AIC of 5000A with a max current of 200A. Again, it's stuff like this that makes insurance companies insist on pro installs.
I'm surprised he rates ANL so highly. I haven't come across any figures that suggest they are as high AIC as MRBF.Not so much promoting them as saying I like the fact that they eliminate an un-fused length of cable between terminal and fuse. I fitted an MRBF to my 280ah battery after reading the CF thread below on AIC which suggests that MRBF are perfectly adequate for my setup. Unless I misunderstand what they’re saying a 280ah LiFePo battery will not exceed the AIC rating of my MRBF fuse.
https://www.cruisersforum.com/forums/f166/lithium-short-circuit-current-aic-298934.html
Edit: The thread above is a long one, so here’s part of the OP’s summary, based on tests he did:
…”For 12/24V systems up to 200Ah, AMI/MIDI, MRBF, ANL and class-T fuses are acceptable. Above 200Ah, only MRBF, ANL and class-T fuses are acceptable.
For 48V systems up to 200Ah, MRBF, ANL and class-T fuses are acceptable. Above 200Ah only ANL and class-T fuses are acceptable.”
Thanks, that's about the price I was expecting and indeed similar to what I was paying four or five years ago.In the UK I can get them , depending on size for well under £50 - up to 200 amp retail at £33 and up to 500a £49
BEP or BlueSeas holders at £30 each
For multi battery systems there are bulk discounts as well
Not sure with the US tariff situation now how de minimus would work but if you're happy with shipping costs I'm happy to get you some here and post them over if the figures work for you
Sorry but i don't have the time or inclination to read long forum posts by random blokes. If you want to follow his advice rather than go by that of established best practice that's up to you.No, have a good read of it. Op seems to be very knowledgeable in this area, and has the equipment to provide actual figures. It’s a long and tedious thread I’ll admit, but what I take from it is that the American boating authority has picked a class T fuse as the best fuse because it’s good enough for pretty much any size battery bank one is likely to have on a boat. But if your battery bank is a ‘smaller’ one, you can use certain other fuses such as MRBF safely.
Well, fair enough then. Will Prowse is some random bloke of the internet but we all seem to accept that he’s put in the hard work and not just plucking facts and figures from thin air. This being a relatively new field I think it’s a question of trying to work out which sources of info can be trusted. The one I linked to seems to me to have also done the hard work and provided proof of that. I totally accept and understand that as a professional you have to go by the official recommendation, which, in the absence of any UK ‘legislation’, is that of the ABYC.Sorry but i don't have the time or inclination to read long forum posts by random blokes. If you want to follow his advice rather than go by that of established best practice that's up to you.
The guy you linked to is an experienced engineer and his tools for the test and methodology are good. I have seem similar tests by several experts and all agree (as I noted in an earlier post) that many factors can reduce the IRC meaning that sometimes non Class T fuses can be used successfully BUT, not every case will have the resistance he found, almost no one will actually check before making a decision and even if they do they may or may not know what they are actually looking at. And I doubt that an insurer would even look at the information that anyone, even a professional, might supply, if it goes against "perceived best practice" / "reasons we can get out of paying"Well, fair enough then. Will Prowse is some random bloke of the internet but we all seem to accept that he’s put in the hard work and not just plucking facts and figures from thin air. This being a relatively new field I think it’s a question of trying to work out which sources of info can be trusted. The one I linked to seems to me to have also done the hard work and provided proof of that. I totally accept and understand that as a professional you have to go by the official recommendation, which, in the absence of any UK ‘legislation’, is that of the ABYC.
Can you make it a two battery set up with 2 fuses? If you have the JK BMS that will run 8 cells (as do many others) so you can have two 600ah packs instead of 4, 300 ah packs. Also saves the cost of two expensive BMS ? Just a thought..Thanks, that's about the price I was expecting and indeed similar to what I was paying four or five years ago.
Shipping to the US sends pretty risky at the moment, however I'm thinking of sending over some NH fuses as they're about £5 a go so I'd they get impounded it's no great loss. They're very hard to get hold of over there.
Seeing as I'm moving to a four battery setup, spending £100 on a fuse and holder for each battery really adds up...
Good idea but the batteries are already made up.Can you make it a two battery set up with 2 fuses? If you have the JK BMS that will run 8 cells (as do many others) so you can have two 600ah packs instead of 4, 300 ah packs. Also saves the cost of two expensive BMS ? Just a thought..
It's interesting information and I have my own experience where a standard Mega fuse worked perfectly to protect a 600ah LFP bank - nice loud bang and a flash and everything cut off (I came to fix a DIY job , I did not fit it, ) where the customer had a big battery pack supplying a 2kw inverter and then wired up a 3.5kw domestic oven to it, hence the bang - as the inverter had a cut off after 3 seconds at over rated capacity that means the fuse blew before 3 seconds (200 amp mega fuse) .
