John100156
After a run down the coat earlier in the week, I was down in the engine room today to trace-out the HFL gennie wiring, still no joy locating a wiring diagram from anybody, and HFL have not responded at all to any requests, which is most disappointing.
Capacitor is a 35uF which I shall replace, there is a 100VA 240/24 transformer (two 12vac secondary windings in parallel) which is then bridge rectified to 24VDC. Which I expect is the control circuit.
The stator/rotor windings are as yet untested, there are 9 cables plus two capacitor cables running out of the main generator casing, all marked numerically as follows:
5 = capacitor
8 = capacitor
7/60/9 = all connected together, so assume that's some form of star point
1 = 240VAC Genny Output (also feeds into primary coil of transformer Live)
6 = 240VAC Genny Output (also feeds into primary coil of transformer Neutral)
3 = copper bar linked to 4
4 = copper bar linked to 3
2 = Nothing appears to be connected to this - end of winding?
? = Nothing appears to be connected to this - end of winding?
Any generator guru's out there that can tell from above the winding configuration, I can then split them and megga them out....!
5 = capacitor
8 = capacitor
