Ian_Edwards
Hi, I've just bought an SWR meter to test my Raymarine VHF and antenna. The meter says that the SWR is 1.38. Is this OK.
It would be great to know if I need to spend some time on the co-axial cable, connections and antenna when the mast is removed for the winter next week.
I'd also like to know where I can buy a 50 ohm dummy load suitable for a 25 watt marine band VHF, all the ones I've seen online seem to be very expensive. Or can I simply make one using a good quality, high wattage, 50 ohm resistor?
